Whats up Eric! Did you buy the same battery that Melvin bought? I did, but I havent opened up the back panel to hook it up just yet.caution said:5Ah battery showed up today. Never heard of Bright Way Group but I'll take my chances.
To a fire-free upgrade![]()
Hahaha. I'll toast to that.caution said:5Ah battery showed up today. Never heard of Bright Way Group but I'll take my chances.
Yo Steve!! You know what, I searched for a dura12-5f on the Amazons but it only came up with one hit, but it was way cheap and had great ratings, we'll see if it holds out long-term! https://www.amazon.com/gp/product/B00456PGPO/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=A18FJ6DZ5DLR7SSLO said:Whats up Eric! Did you buy the same battery that Melvin bought? I did, but I havent opened up the back panel to hook it up just yet.
I bought the same DURACELL battery that Melvin bought. I ordered it from Batteriesplus.com for a lil over 30 bucks. I just removed the stock battery earlier today, and with Melvins help, I installed the new one. Well worth it homiecaution said:Yo Steve!! You know what, I searched for a dura12-5f on the Amazons but it only came up with one hit, but it was way cheap and had great ratings, we'll see if it holds out long-term! https://www.amazon.com/gp/product/B00456PGPO/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=A18FJ6DZ5DLR7S
Thanks trippy![]()
Bro I'm goin over there tomorrow to get one. Ditching this cheapie! There's NO way I'm putting it in there with this type of stuff printed on the front.SLO said:I bought the same DURACELL battery that Melvin bought. I ordered it from Batteriesplus.com for a lil over 30 bucks. I just removed the stock battery earlier today, and with Melvins help, I installed the new one. Well worth it homie
https://www.batteriesplus.com/productdetails/slaa12=5f2
That info applies to all SLA batteries - none of them like a full discharge. SLA cells have a very flat output voltage curve from fully charged to flat (12.9v full to around 12v at 20%). If you drain any SLA to completely flat, chances are it won't recover as most intelligent chargers will treat it as faulty and will not start the recharge process.caution said:Bro I'm goin over there tomorrow to get one. Ditching this cheapie! There's NO way I'm putting it in there with this type of stuff printed on the front.
Duracell Ultras can take 50-150 complete discharges, this one can't even take it once. Even though they're both sealed lead acid with absorbent glass mat I'm getting the feeling I purchased a battery meant for environments where they are constantly being recharged. 3-5 years sure seems low too.
Are you sure it originally used a 12aH battery? The 7aH cells I use are overkill for my DIY projects!!!!mellymelsr said:i had to educate myself on SLA batteries. luckily there are lots of resources with info. Jimmy is correct in saying SLA love to be topped off. After every use I plug it in and recharge back to full then unplug it. It will ensure the longest possible life span. The Bumpboxx uses a 12ah SLA! That is huge cranking power for a portable. I'm upgrading my battery by ordering a 15ah.
The label on the bottom of the Bumpboxx says 12Volts - is it an SLA cell??mellymelsr said:Yeh the Bumpboxx has a 12ah. A 15ah is 2 lbs heavier.
Thanks! I don't know why but I just can't get myself to take it off yetReli said:Nice going!
But you've still got your clear protective film on!
I guess part of it is because I'm still going to be working on the outside of it and might as well keep that skin on there until I'm done. They did so well with rugged hardware for most of it but didn't do much on the case, so I want to install metal corners and some feet that screw in.Thanks! It's crazy how it's nearly 4 times the capacity as the original, gotta love that.mellymelsr said:Nice job! You will notice a huge difference in hours of play with that battery upgrade.
