Cap upgrade Conion c100f then not working
keeney123
Started new thread after upgrading Boombox. This is what happens if one does not recheck all the capacitor value and direction before powering it up. Last year I did this and found a capacitor in backwards in the output amplifier circuit to the speakers.
Also, I want to ask caution where is the ground screw in the back panel as I cannot find one? Never mind I found it. Need to put glasses on. The black twist on knob. Looking fo a actual screw. My mistake.
Anyway, I have opened the unit and attached a picture of the open unit.
keeney123
Finished amp board. Found two other caps backwards and one cap wrong value. Replaced them with new caps. Have attached top and bottom side picture of amp board. Upper right-hand corner is c233 which is not on the capacitor sheet. I believe it is a 47uF 10 v. Will have to verify on the schematic.
Tinman
Yep, you have to double check everything as you go or you end up doing what you're doing, which blows.
Not all boards are the same, some highlight the positive leg and others the negative leg.
You can draw a picture of the way that particular box signifies positive and negative so you have a reference as you go.
I've done numerous boomboxes and just did a clock radio yesterday that only had about 20 caps.
I still double checked every one as I went.
When I did a box, I'd do one board at a time and write down every cap's value and put a mark on top of it after it's written down.
I lay my caps out from smallest to greatest value.
I keep a magnifying glass nearby also, just in case I question something (is it 47 or 4.7).
It can get confusing.
Reactions: BoomboxLover48
Yeah, C233 is 47uF @10V. It's part of the alarm's voltage regulator circuit, dampening inrush current and ensures Q203 gets a steady voltage. It also creates an RC filter with R235, providing ripple rejection (main power comes in on the other side of R235)
keeney123
The direction of the picture of caps on the boards are all like the photo attachment. With the white of the circle being the negative leg and the board color of the circle, light brown, being the positive leg. All caps I have use have a shorter leg for negative and long leg for positive. The short leg, negative corresponds with the black strip of the cap. I do not see any differences on these boards or difference on the caps with short leg negative and black strip. I understand in some instances the black strip can mark the difference between electron flow and hole flow. This is the difference on how an electrical engineer understand the current flow as holes or positive flow and how an electronic technician is taught of electron flow or negative flow. Electrons being about 1300 times lighter in weight the protons it would seem that the electrons are flowing to the positive. However, Electrical Engineers see the absents if electrons as positive flow. If I am wrong, please correct me.
The other problem that makes it difficult for me is I have macular degeneration. I have not big magnifying glass, and I just use reader glasses with a flashlight.
When I was a technician working for Gerber Scientific Products, we used to have a minimum of 2 problems for every board that came through. That is 70% of the boards that failed on initial test had at least 2 problems. We could have anything from 20-ohm shorts caused by dust on the print they use to make the board to solder shorts to legs not put in socket to chips put in backwards. How team of technicians and electrical/ electronic engineers got the time to test and repair a board down to 20 minutes a board. Each board have 90 ICs including processor, Rom and Ram ICs, multiply transistors and photo optic transitions. The boards then went to QC that ran a 72-hour test on the units. We had 3% fall out in QC which we repaired. Once in the field there was less than a 1% fall out. Our service technician would fix those.
keeney123
Thanks, caution, for confirming that. Will save me time. So, this is where they smooth out the DC ripple?
keeney123
In/out board complete. Only one mistake. I put in wrong size cap. Have attach photos of top and bottom of board.
keeney123
Finished upper deck Bd. Only found one problem. The Solder joint that was make to the land run broke. This board runs and pads where different than the other boards. They were not connected to the fiberglass board very well. You can see the rework I had to do on the solder side. The blue circle is where the break happened and I have repair it. The rose circle is not connected but I cut the lead anyway because it was too close.
Wonder if anyone know where to find the fuse 4 Amp. I have circled it in red to the attach portion of the schematic. Only thing I can think is on the bottom side of the main transformer board there is an extra thick run. Perhaps that is fusible at 4 Amps. I have not looked for any zero-ohm resistors that may also be fusible.
keeney123
Hi Caution,
That fuse is for the AC input to the transformer, I believe.
Have attached photo of the power board with a red circle enclosing a curved exposed run. I am wonder if this run is a fusible link that is rated to 4 amps.
Oh yeah, you're right. The one directly on the AC input, on the transformer board, is a 1A fuse. The one you're referring to is 4A. I forgot about that.
It goes between the output of the rectifier and the alarm switch S2002.
It's not mounted on a PCB, so it doesn't have a reference designator on the schematic like the 1A fuse does (FU801, on PCB8, the transformer board).
It's just along the wire and covered with a clear plastic sheath. Not all units have it though, mine don't. I think I've seen it in photos of other owners.
I can't remember which connector wire it would be on, since the schematic doesn't show connectors.
It's either CN803 (Green/Yellow wires) or CN804 (Black/Red wires).
You'd have to look at which of those four wires connects to the center pin of S2002 on the power switch board.
keeney123
Thanks Caution. I will look again on the wire. I don't believe I saw one before.
I have done the lower cassette board and saw no problems with the caps. I, however ran into a problem with many wires breaking off including the wire that goes to bd 15 that is the three set of wires and also the white wire. I am trying liquid tape to try and hold the wire by the insulation instead of hanging on by the solder. Many of the single plug test points and so worth I just solder to the post after they broke before when I had opened it last time and I have no crimpers.
One of the reasons I just powered the unit up last time is because I thought I had a fuse on the output of the bridge circuit. I did not physically check where the fuses were. I, like you, assumed the Fuse near the power output plugs was the diode fuse to the bridge circuit that protects the secondary winding.
Live and learn.
