Small Bluetooth Receiver or Ipod Classic connection options?
soundslikespace
Can anyone recommend the current best small Bluetooth Receiver with RCA output to connect to a Boombox? I see there are a lot of options on the market, but don't want to get something low quality. I'm looking for something about the size of a pack of poker cards.
What about connecting an Ipod Classic? Are there any good small docking stations with 30 pin connection for the Ipod and RCA output to connect to a Boombox? I searched on Google, and they are all discontinued I think, so I would have to track down an old used model.
soundslikespace
Cool! I'll probably get one of those. I was hoping there is a good way to send the ipod signal through the 30pin digital cable though, in case it might sound better.
You can get cheap BT transmitters for car cigarette lighters. I like the idea of using the radio to tune the BT signal! This one 3.5mm Audio out as well.bt kmart.jpg
Reactions: soundslikespace
neanderthal
I, use a small bluetooth receiver called UNIFY. I think I bought it on amazon. It's about the size of a small box of matches or a USB wall plug.
Or get an iPod Lasonic 931, the iPod classic nestles perfectly in the cradle without any adapters and you can pound out some mad tunes.
