Hi,
Just cleaning the tire as I have a slight wobbly playback and also there seem to be a 'bump' that cause the takeup to slightly stop as it keeps turning - a bumpy ride...
Then I found something interesting:
Is it normal to have the inside of the plastic wheel covered with sticky paper tape couple of turns? - see pic
I guess some tech put it in there to 'widen' the rubber diameter so it grips more...
Should this sticky tape stay or should it go?
