Hello friends I just recently fixed my sharp gf 9494 the usually stuff belts caps etc. I also had replaced top circuit board where the power button is cause someone had worked on it cause board was cracked so I replaced it with another board very close too it from another sharp .anyway I put all together works fine the radio the tape, but I noticed the tape sound seemed to drop in quality not loud like it was if I switched over too the radio is blasting I tried different tapes but still sounds not as loud I heard it drop in sound it's been demagnetized and head was cleaned not sure what too make of it unless the tape plug connector is loose? Any thoughts
