Hey Kiddies & mod freaks, back to update the thread with the latest details. I finalized the wiring for the LEDs & managed to tuck the controller card between the tuning board & digital control boards, etc. so that when it's all back together, the controller is not even visible. I used layers on layers of electrical tape to fully insulate the controller so that no shorts or cross connections were possible & the unit uses the same fused power supply as the rest of the radio so if anything goes wrong the fuse will blow right away & protect the rest of the original electronics.
I'm in the process of tapping the DC voltage into the mainboard & past the power block & supply switching circuit so that the LEDs run on batteries, AC or AC-DC adapter, without any extra or special connections. Simply use the blaster as originally intended & enjoy!!
I'm really hoping the M50 woofers warm up the sound & improve dynamic range for the M80. They are a perfect replacement for the stock woofers which were an older paper design with a mesh dustcap--
Same dimensions, magnets, impedance & wattage rating so they should work out awesome & they were the only other woofers that would fit since the chassis is so tight on the M80, it's ridiculous. That's what took me so long to do this mod. I had to find the room, route the cables without causing interference, etc.
Stay tuned. Video to come shortly after testing...
Cpl
