I just wanted to throw my 2 cents in on the M90 volume pot subject.
Here's one of the threads that discussed it:
https://boomboxery.com/forum/threads/for-those-that-have-m90-and-maybe-on-there-wishlist.18208/page
When I took my current M90 apart, I found a tiny metallic piece that was sitting in the bottom of it.
After it sitting on my work bench for a week or so, I inextricably threw it away.
As I realized much later, it was one of the wipers from the volume pot.
The other wiper was gone before I took it apart so I needed a replacement anyway.
I started reading some threads here and found the EWCT5AF20B54 pot as a possible replacement that has the elusive seventh tap.
I ordered one from Greece (It doesn't look like they're available any more).
I installed it and found the balance would only work when centered and it sounded fine.
I didn't know if the balance was working previously since the volume pot wasn't.
After verifying the balance pot was good, I took the new pot apart and compared it to another M90 volume pot.
I found the two inner most wiper arms were in a different position to the originals but didn't know enough about pots to know if this would cause the balance to not work correctly.
After reassembling everything, I was going to live without the balance working.
Then, testing the radio, I noticed the treble wasn't working correctly so I took it back apart and tore into the treble pot finding missing plastic retainer heads on both wipers.
I took the bass pot apart finding the same two heads missing.
I know JB weld or some form of epoxy has become the preferred way of fixing them but I'm partial to good old Krazy Glue.
It's loose so it creeps under and into small crevices so that's what I applied to both sets of wiper arms and let them set overnight to make sure everything was dry.
I ended up taking the new EWCT5AF20B54 shaft/wipers and metal cover from the volume pot apart and crimped it to the bass's board.
I crimped both original Krazy glued pot shaft/wipers onto the treble and volume boards.
I reassembled the amp boards back onto the chassis and powered it up.
Volume works, treble works, bass works and holy $hit, the balance works.
I was and am still ecstatic that after the ridiculous amount of time and effort I put into this box (this was one of many, many problems with this box).
Having all controls working, including the loudness feels awesome.
I'd suggest, if you can find a similar pot, crimp that shaft/wipers on the bass or treble boards and crimp an original pot shaft/wipers on the volume board.
Here is the new EWCT5AF20B54 wipers on the left compared to an original wiper assembly.
My assumption is that the original wipers are basically sawing the plastic heads off over years if being twisted back and forth.
Both treble and bass wipers were missing the top heads only, eventually the bottoms would've broke off.
![IMG_20210129_190331629_HDR.jpg IMG_20210129_190331629_HDR.jpg](https://boomboxery.com/forum/data/attachments/35/35219-e372ed2fa25db6c4700c9d2539cc33c2.jpg)
Here is the original volume board on the left and the new EWCT5AF20B54 board on the right.
You can see my little black jumper for the seventh tap is sticking down.
The original board is bad.
I'm assuming the wipers fell off and cut it up while being tumbled around before falling out.
![IMG_20210118_212131421_HDR.jpg IMG_20210118_212131421_HDR.jpg](https://boomboxery.com/forum/data/attachments/35/35220-73283882179e4e1066d15a9f5fd289b9.jpg)
![IMG_20210130_135608757_HDR.jpg IMG_20210130_135608757_HDR.jpg](https://boomboxery.com/forum/data/attachments/35/35218-553727eedaab5dac17996c65254eb0ed.jpg)
Thanks to caution and chuckulaa who's previous work and posts led me in the right direction to get mine up and working.
