C-100. Screws.
Megablast_73
Hi ! I need to sort out the screws holding the housing in my C-100. Some idiots lost them a while ago, and I think I only have one original left. Can anyone tell me the correct dimensions for these screws? I think there are 4 long ones and 4 short ones. I'd like to avoid damaging the already weak threads. I can't find any specific information.
I posted some info on them in comment #22, maybe it will help you
Reactions: Megablast_73
Megablast_73
Thanks, “caution” for bringing this post to my attention. It was very helpful. I have one more problem. The upper deck of the cassette player suddenly stopped working. I noticed a loose connection on the CN207 connector. I fixed it. However, it still doesn’t work. I checked the connection from CN207, and the cassette loading switch works. Damn, everything is a bit unstable in my C-100. Near the CN207 connector, I see an empty space marked C284. Did that capacitor disappear, or was it never there in the first place? I can’t locate it on the schematic.
Translated with DeepL.com (free version)
