Panasonic RX-DT680 CD player no longer reading discs at all
fingersmaloy
Hey everyone, I posted a thread on this topic a couple years ago when the CD player started to go, but it has since stopped working entirely and recently I've spent a lot of time troubleshooting it and am getting desperate, so thought I'd try again and see if anyone might have some advice.
After lots of searching, I concluded that the issue was likely a dead laser, which is apparently a common issue with Panasonics of this era. I finally bit the bullet and dropped close to $80 on a new laser pickup from Ebay. This one.
I was able to install the new one, and also applied fresh lube (white lithium grease) to the worm gear and metal shaft, but the unit still wasn't reading discs. However, I was able to verify the following:
1. The spindle spun when I inserted a disc
2. The lens automatically slid along the track to get into the correct position when I held the lid latch down
3. The laser shifted vertically to adjust focus when I held the lid latch down
4. The unit could tell the difference between when a disc was inserted and not (it said "No Disc" if I held the lid latch down with no disc in place. If there was a disc, it would try to spin it)
From the above, I *think* I can surmise that there's nothing wrong with the spindle motor or the gears moving the laser, and the replacement laser is at least powerful enough to detect the presence of a disc. The Ebay store said it was brand new, but it showed signs of oxidation and wear, so it's a little sus.
Also sus: The laser didn't come with one of those anti-static solder beads you have to remove. The Ebay store said not all lasers do, and this one simply doesn't. Does that strike anyone else as odd, or is that legit? I've also heard of some lasers coming with a clip or pin instead of a solder bead, but this didn't have anything.
In desperation, I decided to tempt fate and try blindly tweaking the potentiometer. I painstakingly tried several different positions, but none helped, nor could I see any difference in laser brightness when looking through my phone camera (it was a tiny, tiny red dot in all cases).
I reached out to the store and told them it wasn't working despite much troubleshooting, and to my surprise they sent me a replacement with no fuss, but I just tried installing that one today, and…same result.
So, I'm at an impasse. Anyone have any advice, thoughts, suspicions? I don't want to mess with a pot again without an oscilloscope and someone who knows how to use one. I don't know where to take one of these things to get serviced in 2026. Desperate to turn this into a win. I guess I should also mention I did the line in mod on this boombox a couple years ago, and that still works fine, as do the tape decks and radio.
Well, thanks for reading.
When you random and blindly tweak the laser current control, you will seriously risk damage to the laser, or blow it. Laser (LED) diodes have little tolerance for excess current. The second current goes over the threshold, it is totally unforgiving. That's why the service manuals provide very detailed procedure for measuring the current while making the adjustment. New lasers shouldn't require adjusting current upwards anyways since presumably it has not lost it's brightness unlike a used and well worn laser. I highly recommend you pick up a service manual for it to ensure you are adjusting anything properly and definitely not blindly. Also, you typically can not tell the laser current consumption by looking at it.
fingersmaloy
Thanks for the reply. For what it's worth, I knew messing with the pot was risky, but this was after days of troubleshooting and I thought I was at a point where my options were either try tweaking the pot blind, or buy and try to learn to use an oscilloscope. I had already read that blindly tweaking the pot is a bad idea, but also saw enough success stories on YouTube and elsewhere that I thought it was time to hedge my bets. I wasn't ready to drop another $100+ on an oscilloscope to measure what might well be a dead laser to begin with.
I guess I've just been holding out hope that there might be some other thing I could check, some other likely culprit besides the laser. It struck me as unlikely that both lasers this Ebay store sent me were faulty, but since making this post I was able to find a repair shop an hour away who spoke to me on the phone for a while and said these aftermarket lasers are almost invariably trash. I asked if he would be able to use an oscilloscope to measure the output to confirm for certain if it was the lasers, and he just said, "It is." He also confirmed that it's very unusual for these things to be shipped with no anti-static protection of any kind, so there's that.
Anyway, I've already initiated a refund. I do have one other laser from elsewhere on the way, but if that doesn't work, plan C is to try and poach a first-party laser from some other Panasonic machine at some point.
