JVC PC-X130 Display Lamp Replacement?
Hello!
I just acquired a JVC PC-X130, and one of the bulbs in the orange LCD display is dead (there are two bulbs, one on each side of the display). The service manual cites FSGZ0001-001 as the part number, but I can't find a replacement or a cross-reference for the part.
Does anybody know what a good replacement would be?
Okay, I may have asked too soon. I tried JVC Accessories, not thinking they’d have it anymore, but it looks like they might. I placed an order and am keeping my fingers crossed that they can actually fulfill the order…
Just an update, in case it means anything to anybody later: JVC Accessory Store (jvcpartsstore.com) has still not yet fulfilled my order. I received confirmation, but nothing since. Still keeping my fingers that the parts still exist, but not counting on it.
The lamp in question, though, started working again, intermittently. I removed both lamps (they twist off the back of the LCD/Operation P.C. Board) and applied some DeoxIT D100L (the viscous, red stuff) to the contact points. Now, both lamps are working consistently.
I replaced the RW/FF belts and carefully cleaned off all of the residual belt goo from the mechanism. The speed is dead on and constant with the original capstan belts (I thoroughly cleaned them and the pulleys then used a test tape to confirm speed), but the auto stop was clicking, intermittently, during playback (on whatever deck wasn't in play mode). I regreased the autostop gears on both sides and haven't heard the click since (keeping fingers crossed on it'll stay quiet).
Reactions: Just MV
On the jvc kabooms, I typically immediately swap them out for LEDs, they use less power, light more evenly and will never burn out.
On some equipment, I go that route. I've had good luck modding the backlight on some older JVC displays that have the mirrored housing for the bulb (e.g. PC-X300 and PC-V77). I find that it's really difficult to get the right color and get the diffusion right with these flatter, newer displays. Anyhow, I like the color and vibe too much to mod it to LED...unless it become absolutely necessary in the future.
general k7 and power
I hope these are helpful! I would have to do a lot more teardown to get to the power supply section, and I don't have the time to do that today. If I ever need to dig back there, though, I'll provide pictures of it.
With everything working properly now, I did a test recording from CD to a new type I cassette. I shouldn't be stunned by how well it did- I know these are very, very basic mechanisms, but JVC had bottled some kind of magic with these.
Reactions: Brutus442
This is my kaboom that I swapped out the bulb for leds.
The thread on how I did it including how the leds were installed can be found in this thread:
Reactions: tisaperfectdayelise
Just MV
Thank you so much!
It's a high-quality product; I'm very familiar with JVC.
However, some boomboxes are difficult to navigate.
Beautiful!
Thank you so much!
Beautiful!
You are most welcome! The JVCs are quite nice. I went on quite a nostalgia tour this year, restoring a whole bunch of JVC boxes. It all started by wanting to do a belt replacement on a PC-X100 I've had since the early 2000s. Nostalgia took over, and I found myself seeking out the PC-XC11 I had in high school, and before I knew it I had a PC-V55, RC-X510, PC-Y555, PC-V77, PC-X300, and PC-X130 on my bench. So, I've seen the inside of a lot of these this year. I always loved the Hyper-Bass, 3D woofer configuration that JVC used, so I wasn't pleased in the 90s, when they went away from it.
While working on all of these machines, though, I gained an appreciation for how these improved over time (e.g. how streamlined yet not cheaped-out the PC-Y555 is compared to the V77; or how much more elegant the woofer situation is in the 100 vs the 300). Although the 130 and the C11 don't have that head-turning (and honestly imbalanced) low end of the Hyper-Bass boxes, the fidelity is still quite impressive for what they are; and the fact that you can push them harder without having to futz with the eq to stop the woofer from rattling actually makes them more practical than their more interesting older brothers. The 130 is downright elegant in design from a repair/maintenance perspective, which was kind of shocking to me (I almost destroyed ribbon cables MANY times, trying to get the 100 reassembled).
All in all, there wasn't much repair work that had to be done on any of these. All of them needed new RW/FW belts, but all but two capstan belts were still working perfectly. Only one mechanism needed to be re-lubricated (they all got re-lubed, but all functions were working). All electronics were still working fine, except for one component: one still needs a new supercapacitor for the tuner section, so it can remember what station it was tuned to after shutoff (the PC-X300). Three record/play switches needed a healthy amount of DeOxit (as they were producing a terrible thumping during playback on the rec decks). . One common failure, though, is the pause button on the rec decks. Two of those failed, and although I was able to find the spring and plastic caps rattling around inside the units, I didn't seek out replacement parts for them (I never use the relay function nor the pause feature anyway).
I appreciate how resilient the plastics are, as well. Some of these looked terrible, upon arrival. The greatest length I took to restore the looks was using black leather dye on the speakers for the 130; those had faded to a light tan color, when the box arrived.
The RC-X510 and the PC-V55 went up on eBay- they're nice, but don't scratch the itch the way the other boxes do. Here's the curated collection I'm keeping...for now:
XLVII
Nice shots. On YouTube a sagging belt fix was boiling belt for 5-10 minutes. Will try soon; seemed to work for him. Any thoughts regarding this solution ? ...
Honestly, if the belt is to the point that it's not providing enough tension, I would just buy a replacement, particularly if you know the size. If it's slipping, and you don't have the measurements, I would do the boil to maybe get a more accurate measurement? If the belt is fine, I suppose a boil couldn't hurt anything. ...but any time I've done the boiling thing, it just buys me a little time- it's not a long term solution nor a replacement for an actual belt replacement.
Reactions: XLVII
XLVII
Some\nOf us don't live in a land of online amazon instant gratification , and i'm assuming there are also younger readers without instant access to ready cash. Thought the boiling might be a handy solution. I had wondered about reconditioning rubber with a chemical , but the boiling made so much sense.
Sounds like you have it figured out
Just MV
Superb collection!
I've almost had the chance to take them all apart with the 3D Hyper Bass, but the PC-X100 is quite incredible in its bass response!
Each model is slightly different.
The PC-V2 is still exceptional for 1987! The sound is truly amazing, with the CD player being superbly filtered, and the radio and cassette player are superb in both playback and copying. However, it's difficult to repair in order to access the internal components!
