Sharp GF575 left side audio is quiet
Jud55
I purchase this about 6 years ago and had it stored in the loft and im pretty sure it worked fine before putting it away
I came across this thread here
Mine is pretty much the same except there is volume to a small degree, im no expert in any type of electronics , would cleaning the slider be a good place to start if so what do i need to buy to do it, its on all the functions as both tapes do it and so does the radio.
Thanks
Lots of connections pass through that record/playback switch. Radio might work then tape, line in and other functions might not. So, it is likely that switch dirty and oxidized like Superduper mentioned.
Jud55
Got ya, sorry for the dumb question but what part are you referring to by "record/playback switch" and what would i need to clean it, or is it a case of swapping it?
Yes, it is a long bar shaped switch, typically on the main circuit board. Clean by orienting the boombox so that the switch is pointed North/South. Spray deoxidizing electronics cleaner into the top end while actuating the switch to allow the solvent to work its way down and through the switch. The switch is spring loaded and may need to be moved scores (50x or more) for thorough cleaning. Blot up excess solvent when done and allow to dry before powering up.
