Sanyo M9935K Belt Question SCQ vs SQQ?
JonV
Hello -
Changing out the belts on my Sanyo M9935K.
The stickied thread for Sanyo shows I need and SCQ10.0 and an SQQ6.0. Is the SQQ a typo? I get no search results for any belt with that prefix nor is it listed in the Russell reference manual.
Also, there is no mention of the counter belt. Any idea what that one is? It has a circumference of 6" but much thinner than the other two.
Thanks in advance!
SQQ is a typo, it's that way in the Russell reference on page 75 (link to PDF)
It's supposed to be SCQ. SC is short for "Square Cut" (see PDF page 278 for all SC codes)
I don't know if the original paper document was in rough shape or the OCR software they used was junk, but yeah, there are a lot of errors.
Tinman
That reference catalog doesn't always show every belt.
Counter belts are usually thin since the counter turns so easily.
If you go to the last page of the PRB cat, it'll give you an idea of the different belt thicknesses (scy, scx, scq, etc.).
JonV
Thank you for confirming , that's what I thought.
