When I play a tape on deck 2 the right side speakers and the red row of lights for the right side don't work, only hear it faintly when I put the volume up.
Anyone out there know why?
Thanks.
Thanks.
If I understand right:These are the lights I mean, the right side don't work as with the right side speakers but only when I play a tape on deck 2, all the rest works fine.
This was my mistake and I edit my answer - no capacitor on right side.I don't know if there's supposed to be a capacitor on the right side just above the lights, like on the left?
Anyone know?
I don't know either but it looks like the right side could also missing a resistor that the left has.I don't know if there's supposed to be a capacitor on the right side just above the lights, like on the left?
Anyone know?
THIS.![]()
Record Switch Bar Example
A few boombox problems are caused by a dirty, or faulty, record switch / bar. Most of the times, the primary symptom is a high-pitched squeal when playing cassettes. Thorough cleaning with DeOxit or some other electronics cleaner will generally be the simple fix. Here is an example of what a...www.boomboxery.com
No the boards look right. It’s the same setup as mine missing resistor on left and no capacitor on rightI don't know either but it looks like the right side could also missing a resistor that the left has.
