JVC PC-W35 drive gear
rivetmaster
I've spent some time cleaning and restoring this JVC PC-W35. The last step comes down to the drive gear on deck 2.
Are there any spares out there? I've looked in all the usual places. Does anybody 3d print these?
14.5mm diam
1.5mm id
46 teeth
I don't want to bin this boombox just for a gear wheel.
Hope you can help.
goodman
I assume that this JVC has a Tanashin cassette mechanism.
Such a mechanism you can found in many cheap boomboxes - eggs and similar...
You should find another boombox and use it as a donor.
Reactions: rivetmaster
rivetmaster
That is good to know. I'll start looking. Thanks
rivetmaster
Well, it took 2 days of searching to find these. Not easy since the listing says 'pinch rollers', but that is clearly the Tanashin mechanism.
Many thanks for the help
Reactions: Tinman
