Extra Spring for Idler Tire Issue With Blockbuster 3-5259A
BoxBeats
I recently saw a restoration photo of the Blockbuster 3-5259A where an extra spring was added to bring more tension to the idler tire. Has anyone installed one? What size spring and source to buy? Thanks!
Photo for reference:
Your just trying to overcome the the age of the rubber. I would first resurface the rubber on the idler tyre by placing in a drill and spin on flat sandpaper. Or replace with an o-ring.
When you add more springs to the mech it can add to the wow and flutter
BoxBeats
Thank you, will do.
