Werewolfbox
I just got a 680 and I want to preform this mod. I have never soldered any electronics before, but I'm not afraid to try.
What size/gauge/type of wire should I use?
Just go to first page of this topic and you find answer of your questions...
Were you able to do it bro?I just got a 680 and I want to preform this mod. I have never soldered any electronics before, but I'm not afraid to try.
Okay thanks but, i see one little white cable, it's right?In the first post has 13 steps, as well as lots of pictures. they clearly show what cables are used - quite ordinary.
With the right tools and skill - this mod is done in about 1 hour.
Reviving this thread in regards to DT610
It looks like there's no seperate tape deck circuit as in dt680. I'm thinking if attaching to pins 5,6,7 to equalizer circuit, w303. Any dangers or voltage issues that might occur?
