Hi,
I managed to open one of my newest boomboxes and tried to fix the cassette player, put the new belts on and started to put it all together when i put the screwdriver on the wrong spot (while power was on) and sound went totally missing. Few lights are still on, but nothing can be heard, no matter using Radio or cassette (cassette is not working).
I have checked both fuses and they are ok. Also i have checked both speakers and they work, cause u can hear lite hum coming from the both speakers.
I do have CS-600 service manual downloaded from the Internet, but my knowledge regarding how to check something (capacitor or something else) with a multimeter is very limited, due to i´m not electrician nor have education for it, doesn´t help the possibility to fix the problem..Although i really would like to learn
I put some pictures along of the board, if somebody would point me some advice, where to start looking the problem
Thanks
Kris
Thanks
Kris
		 I have a very simple multimeter, in what position it has to be when checking e.g. transistors or diodes and most importantly what the multimeter should tell you in numeric values ?  If some of you have downloaded the CS-600 service manual as i, do u have any suggestions what part (s) should i check first ??
