Hi. This is my first post ever. I bought a RC-550 and I need a power supply cord for it. It says "DC-12V". Here is a photo. Is this something I can find somewhere? Thanks if someone can help. It's working off of the eight D-Cells right now.
if you find a socket on it that says AC then that means you can plug it in with a simple cord. if you don't have a cord then post a picture of the socket the cord plugs into and take it from there.there should be another plug-in location either on the back of the Boombox or on the side that you put a AC cord in , this will allow you to just use the cord to plug it in the wall mind you there's multiple voltages for these boomboxes depending on whether you live in North America or in Europe so you have to make sure that the voltage is set accordingly there should be a voltage selector on the back of the box. make sure you check the voltage before you plug it in.
it's most likely already set to the right voltage you just have to find the right AC cord.if you find a socket on it that says AC then that means you can plug it in with a simple cord. if you don't have a cord then post a picture of the socket the cord plugs into and take it from there.
That's not standard the pins maybe two close together. It's actually a Rectangular plug similar to a shaver.
AC Plug Types
UPDATED Septemember 7, 2016 Every now and then there's a post about AC power cords and such, so I thought I would create a graphic that can help when someone is looking for a particular style plug. All you would need to do is say, "Hey, I need a 3 power cord" or "Does anybody have a 5 cord for...boomboxery.com
Can you measure the distance between the two pins on your box? These old boxes have pins closer together and not compatible with new cables.Thank you. Ordered. This won't be my only question, ha ha. Appreciate this resource.
Why would you this is a so called Grail?That 0.75 mm clearance on either side of the holes make no difference at all to fit in. The female pins will easily wiggle/jiggle and accommodate in the plastic holder of the plug.![]()
Because nothing will happen to the pins at all!Why would you this is a so called Grail?
