So I just picked this Boombox up for the equivalent of $19 USD. The Sound is awesome compared to my Sanyo M-x650k. Besides some scuffs/scratches/worn areas, here is a list of the problems/needs:
- Needs 2 new antennas
- Eject arm broken from inside
- Cassette buttons do not function
- Capstan turns/motor runs while unit is on regardless of whether “tape” “radio” or “line in” are selected.
- One knob (bass/treble/balance) has a crack in it that makes it loose. How should I fix it? Glue and hold it tight with a rubber band until the glue dries?
- The subwoofer grille is intact but very dirty
- The main speaker grilles are dirty or rusty? Might need painting
- Only 3 screws out of 9 (I think) that keep the back panel are functioning
- The “line in/phono” switch works however the plastic switch has broken off
- Battery cover is missing
