Finally summoned the courage to change the belts on this one. While I was in there, fixed the big plastic timer switch and thanks to Boomboxery did the shim fix to get all the LCD clock segments showing - this is an old pic ...looked a bit ILL didn't it?
So, should I paint the crack to make it a highlight, or no?
Thanks to all who recently chipped in
on the belt fun. Only damage I did with all the work was a couple of those bendy plastic catches that hold the tuner dial and the clock PCB. They are getting very brittle so watch out!
