My bluetooth switcher setup
xiracerxix
Some have asked about my bluetooth and 3.5mm audio switcher setup. The cool thing about this audio switcher and I found this by mistake is that it's only an isolation switcher and I'm glad it's analog. You can simply depress all buttons and you will have audio outputted to all of your boom boxes because it runs each channel in parallel. I've been running this for a long time w/ any issues. The Bose adapter is the input to the switcher to feed the audio. I also have an esinkin bluetooth adapter for which I highly recommend for a cost effective solution. The Bose is ridiculously priced when I acquired it years ago and I bought it for my Sonos which was never used.
Here's are links
3mm switcher - Note, I couldn't find any other ones with an 8 out configuration. Technically you can probably daisy chain these, but obviously test it out.
Bose bluetooth (it's actually discontinued - get the esinkin)
Esinkin bluetooth adapter
Q's, please don't hesitate to reach out. Happy to help and answer.
Reactions: peturssc
Inactive
Nice setup, so I think you can send via Bluetooth to 8 devices Stereo analogue Music? I guess if you have 8 running at once it must make a huge sound even though you are down scaling.
xiracerxix
Thanks! Potentially, if you set it up properly. Yes it would be loud!!! but Awesome.
