Ok so the first 8989 I bought was cosmeticaly a bit of a mess but it was working ok. Recently though I noticed that the tape motor was making a loud screaching noise when activated and it also needs a set of belts. It sounds like the motor needs bearings so I pulled it apart last night and done a few changes. Firstly I took off the tape door at the front and then disconnected the motor altogether. What I found out was that as long as the play head has power, it will play even if the motor isn't running.
The belts were stretched so I removed them, put the tape adapter into the deck and rotated the mechanism by hand into the play position, plugged in my smartphone and it plays perfect. Not having the motor running is a major benefit as no noise or moving parts to wear out. Just as long as the head has power and is set to the play position, the box will play any source you can connect to the adapter. The radio still works fine too as when you press the radio button (on) it over-rides the tape deck.
The reason why I had to remove the tape door on the front is that the tape adapter had to be put in place before the front of the box was put back on, as I had to set play manualy by turning thr mechanism by hand. but it worked fine. What I'm going to do is attach the adapter jack to the case around the back so that no cable is visible and also somehow reassemble the front tape door. This will be for the weekend I think.
