Yamaha YST-C11 FM Tuner Not Working
reynolds
The FM tuner on my Yamaha YST-C11 isn't working. I actually came on this morning, but now it isn't working again. The AM works, but not the FM. Not in Stereo or Mono. Please help.
Welcome aboard, reynolds! :hi:
Member Skippy1969 has that same unit. Maybe he'll see this thread and offer some assistance. ;-)
thanks for joining :-D
and just hope/pray that your problen is just a dirty//touchy switch :angelic:
because that yamaha digital tuner may be hard to fix or replace.
where are you from ?
the radio shack chain sells "DEOXIT" spray --
but most ALL electrical contact cleaner (any hardware store) works
almost as well
if you are very lucky --
turn the power off -
lay the box on its back --
and try to spray the switches LIGHTLY --to get the liquid inside
if that wont work --send a PM to member 'skippy'
he can tell you how to carefully open it up
so that you can get to the real switch contacts.
good luck - keep us posted -
its a tremendous sounding box :yes:
