Where to get replacement antennas for TRK-8080?
DrmZ
Where to get new antennas for a TRK-8080?
It would be great if they had black tips like the original ones.
MyOhMy
Perhaps a TRK-8080 owner could take measurements and post the details? There's a fair old chance other TRK-XXXX models use the same aerial/antenna as many of the boxes are/may be a similar size.
DrmZ
That would help, yes.
On my box only the lowest part ist there - everything above the screw is missing.
They seem to be thicker on the bottom because other antennas who fit in length are still loose when screwed in (with two washers).
The bottom part is a lot bigger than on other boomboxes.
I was hoping someone can point me to a seller that has new antennas in various sizes.
Antennas with black tip will be the hard to find I guess.
