Hey all,
Following the manual for disassembly, the steps to take the player door cover off are
1) remove dust cover (done)
2) open the door (done)
3) remove 3 screws at cover (from inside the door), and take the cover off.
I'm on step 3, and I've taken out the screws, and the grey cover is coming away from the blue interior of the door, but if I try to remove it, the bottom of the cover seems pretty stuck. I'm hesitant to put a lot of force on this since it's a big piece of plastic, but is there a catch or something at the bottom that prevents the cover from coming loose? The manual (of course) doesn't have any pics of exactly how you take the door cover off heh.
![vz-2000 player door.png vz-2000 player door.png](https://boomboxery.com/forum/data/attachments/37/37843-4f61975ad379cabb3a798c333e247549.jpg)
