by which company mostly send or receive your shipments? some especially for something? UPS, FEDEX?
santa maybe leave me something in Uruguay ,
Lasonic TRC-920 said:USPS (United States Postal Service) and UPS (Under Paid Slaves) are the only ones I have used.
UPS trashed my TRC-920, but again it was poor packing and I think they have an elephant sitting on boxes at the end of the conveyor belt.![]()
MasterBlaster84 said:Lasonic TRC-920 said:USPS (United States Postal Service) and UPS (Under Paid Slaves) are the only ones I have used.
Chris I once worked for UPS for 1 day unloading the trailers and I can tell you the pressure is on to kick ass so you don't care what happens to the boxes. They expected me to unload one of those big semi trailers with the extra deep false floors at a rate of 1 trailer per hour, that's doable but you have to move very quickly. I can tell you that a lot of boxes fall off the steel roller conveyor as your flinging them, this is one reason I don't use UPS if at all possible. When I do have to use UPS I make sure the item is packed very well and even double boxed where possible.
MasterBlaster84 said:Packing is 95% of the equation really, if a box is packed with newspaper and or in a box that's to small I can't fault any shipper. In this case the issue is all with the seller and there crappy packing.![]()
Funny I worked for UPS for over 10 years first 6 as part time package pusher and 4 years plus as package truck driverMasterBlaster84 said:Lasonic TRC-920 said:USPS (United States Postal Service) and UPS (Under Paid Slaves) are the only ones I have used.
PlusMasterBlaster84 said:Packing is 95% of the equation really, if a box is packed with newspaper and or in a box that's to small I can't fault any shipper. In this case the issue is all with the seller and there crappy packing.![]()
If wrapped real good less breakage would happen
