TPR-950 Replacement Motor?
Mine is apparently devoid of any markings.
Anyone got any idea what voltage it is?
I'm assuming it's CCW based on the position, but please correct me if I'm wrong.
Thanks brothers!
monchito
yes glue mostly all are ccw and 12v so you can use any from a parts box as long its 12v and ccw
Thanks Ramon! Excellent!
Roddy: I just rebelted it and it after a little bit (I'm talking less than an hour) of use it decided to stop. The rest of the mech seems to be all fine and dandy. The motor is very warm to the touch though and even with the belts off it randomly refuses to spin. And once it stops it doesn't recover for a long time.
I told my repair dude about it and he was pretty convinced it's the motor needs replacing.
I'm happy to replace it, now that I'm familiar with the insides (thanks to Ramon!) I doubt it'll take too much work, and my repair dude charges me bugger all for them.
blah blah
if it just stops randomly and then starts i believe it is a goner. my panny5600 was doing the same, i popped a replacement and voila it was pumping...
