Got a problem with what I think is perhaps a cleaning issue but not sure.
Radio function is good though there is no FM Stereo, I can get the light to flicker on when moving the siwthc between AM and FM quickly.
The deck function just has loud static noise, can't hear a tape playing above the static noise but the functions on the deck do work.
I've tried cleaning the headpohne and mic sockets, the line in sockets, the little switch in the power inlet and all control sliders and knobs but none of them have any affect on the level of static noise ie: it doesn't go louder or quieter at all. The mode switch has has a hugely thorough workout with switch cleaner.
When I got it the deck was stuck in play mode with the heads engaged but a little steady work freed them and they work as expected now with the press of a button. I've changed the single belt this deck has. Since this is a logic deck there is no record bar to clean either
Not sure where else to look ?! Anyone know about a schematic ?
![Dunce :dunce: :dunce:](/forum/styles/default/xenforo/smilies/boomboxery/dunce.gif)
