Tape 'B' door - how does it hold on and swing?
DPaignall
Hi good people,
The cassette door on the upper deck has gone and fallen off!
Does anyone have a pic of how it attaches and what makes it swing up and down.
There is no spring mechanism that I can see.
Hope you can help me get it reattached.
If its anything like a lasonic it has a metal bar that holds the door in place with a coil spring wrapped around that one side of the spring is anchored to the front case and the other against the door flap.
The spring is very weak but if it puts too much pressure it will make the tape not want to eject properly. It only needs enough tension to hold it tight to the front case.
DPaignall
Thanks again, I've nearly finished it's refurb and will post a thread of how it was and how it is now - there's quite a difference!
