Speaker Help For a GF777 and VZ2000
alfie
Hey guys, I'm pretty new to collecting and am hopeless at the tech side of things so some help would be appreciated!!!! On my Gf777 i'm getting very, very low volume on the lefthand side (virtually none at full volume), however the right side is fine. On my VZ2000 i've got the same problem but on both channels. Is there an easy fix or am I in for major surgery? Any thoughts would be much appreciated......................................Peace>>>>>>>>>>>>>>>>>>>>>
If a good thorough cleaning of the controls do not restore sound, then it's probably something much more serious. Start by cleaning all the controls, especially the function and record bar switch.
alfie
OK, cool. Now, how do I do that? I assume I'm going to be opening her up for this? Some direction would be great coz I dont want to do any more damage..................Cheers.................................
kingrat2010
u need some deoxit spray i think
but i dont know if u can do it from the outside or u have do open up ur beauty
i need that information too
alfie
Hi Floyd, tested the gf777 and I'm still getting the same problem with the headphones on. Is this a good or bad sign???????????????????????????????? Thanks for the help mate.......
if it's the same with headphones it might have a bad amp ic chip ,i thought a had a spare gf 777 amp board i'll have to look and see if i still have it.
alfie
Hey Floyd, if you do and think it might solve my problem you'd be a legend in my books!! Let me know if you can find it and we can take it from there. Thanks again for all your help mate.............
Before you go through all that work -- suggest you verfiy/confirm that the amp is the issue.
Take a line-out signal and play it back through another machine. If both channels are playing back good, then chances are good that the issue is in the amp module. IF the same symptoms present through the other machine -- then the issue is FORE of the amp and will not likely be resolved through an amp change.
:agree: and if you need it i do have the spare amp board .
alfie
Hi guys, just tried the gf777 through my sanyo mk9994 via the line out and it came through perfectly on both channels so i'm thinking it sounds like an amp issue from the info you guys are giving me. If you're happy to do a deal Floyd i'd be very keen on the amp board!!!!!!!!!!!!!!!!!!!! Thanks again guys............................
if you still need it i still have it.
