sound slowly coming in feature!
My Sharp got that advanced feature of sound slowly coming in (not like a thud...but in a few micro seconds) when you switch from tape to radio function.
It never scare you when you flip the function switch.
I forgot what you call that feature....
im_alan_partridge
Which model is it?
Retro Addict
My GF-9000 does that, if I'm listening to the radio function and press the radio button again, the sound disappears and comes back again slowly. I don't remember it being like that when I first got it, or not so pronounced. Maybe mine needs a recap?
Superduper said:
what happens when you turn it on, turn it off, then turn it right back on again?
[SIZE=medium]I didn't see any noticeable difference.[/SIZE]
[SIZE=medium]It is not a sound rushing in that will scare you when you change function from radio to tape. That is it.[/SIZE]
[SIZE=medium]If you move the function switch on old amplifiers with say 1/3rd of the volume, one would jump off from their seats.[/SIZE]
I don't think so!
I have to agree with Jimmy. Leaky caps or oxidized connections. & these old boomboxes simply can't be compared with or to more sophisticated electronics with softstart technology or newer electronics with digital circuits. Its a bug, not a feature.
Thanks Norm! Good to know that! :yes:
There have been some Sansui owners who didn't like the sound of their amps & receivers after a recap. As the capacitors age, the sound becomes muddier and less accurate. Some owners get used to this sound but since the sound reproduction is no longer accurate, it is technically distortion. Not that all distortion is bad, in fact, merely adjusting the bass/treble could be construed as distortion. In any event, because the change in sound is gradual, the muddier bass & loss of treble is gotten used to. Upon a full recap, some owners dislike the "new" sound saying it lacks warmth. In fact, its probably closer to original after the recap as amps should be as transparent and color free as possible, with sound shaping being introduced deliberately and not as the result of an aging amp components. Bottom line is that as long as you like your bug, it can be to you as a feature. But I don't they were that way when they were initially released.
Great information Norm!
Thanks again for your valuable input! :bow:
The bass and treble are of superior quality with this box. In that case I hope it is not a cap issue in the audio stage. Again I am working it on batteries and that could be another factor which can cause this issue because of low power.
I will change it to mains current tomorrow and see how that goes.
