Sony CFS-500 Help
fresh produce
Hey everyone for some reason my Sony sound keeps fading in and out when I play a tape, but when I use the radio it doesn't fade at all any ideas what it might be? Thanks for the help
skippy1969
BoomboxLover48 said:
Clean the long record switch and see if that helps!
Yes and you might check the function selector switch while your in there and give it a good cleaning....... ;-)
I've the problem your having happen before if it is dirty........
