Replacing Cassette doors
mkctran
I am new to this forum, I need help replacing both Cassette doors. I have the donor box on the way, I just dont know how to go about it.
Any pictures would be a ton of help!
mkctran
BREAKDANCER BD 8000 DISCOLITE BOOMBOX
You need to remove the chassis out to access the tape doors.
I think it will be similar to working on a Sharp GF777 on how to remove the chassis.
Our members here should know more about how to work on this box.
No chassis in this one and the front part attaches I believe separate.
Bad Boy Bill
Gaffer
Hi there anyone know how to fix fm signal problem on discolite vela dynasty.
I don't have a strong fm signal. Not to sure how to fix. Or if it needs a clean.
If anyone could help. Be great for feedback.
Does FM come in Stereo and led light up? First thing I would check is antenna hooked up and that the post or connection to board solder joint isn't cold.
