toshik said:
Most of our boomboxes used premium OEM capacitors which simply do not fail by themselves.
Funny, because I find failed/out-of-spec electrolytic caps in blasters all the time. It's not necessarily all of them, but still, quite a few.
I guess I'm picking up the wrong radios...
As for re-capping the C-100 - Go for it!
Like Norm said, re-capping the electrolytics in the tuner board probably won't help with reception, but it won't hurt either.
My C-100 tends to get noisy in the tuner section about once a year. It seems to be a grounding issue with the tuning capacitor, which I clean with a little
zero-residue tuner cleaner (
DO NOT USE DEOXIT FOR THIS). Once clean, the reception is excellent.
I'm not saying this is the issue with yours, but I figured I'd throw it out there.
I'm sure someone will crucify me for cleaning the tuning cap, but it works in my case.
