Realistic 14-778a Cassette Player Belt
Composer1a
Hi there! I am new to the boombox world but have waited a long time. I have a Realistic 14-778a which works great except for the cassette player. Would anyone happen to know what size drive belt I would need and where I may be able to get one? Thanks a lot!
welcome aboard :hi: This is a very nice box. As a matter of fact the best bbx Radio Shack put out (in my opinion) :-D The only problem that this box usually has is there is a part on the deck that usually breaks and usually no good replacement parts for it. This part is located in center and will cause the deck to auto shut off. It can however be repaired with jb weld (as i got mine repaired by a member). These are your belt sizes14-778 Belt SCY4.6, Belt SCA8.6, Belt SCX5.1 Hope this is helpful ;-) You may want to try and replace belts 1st to see if deck is working :thumbsup: This is a good supplier for parts/belts http://www.studiosoundelectronics.com/
Composer1a
Thanks a lot for the info! I have looked for those belts but they do not seem to be available anywhere that I can find. I checked the site you gave me but those codes do not seem to show up.
