Well the old magic switch cleaner (maplins sell Servisol which is what I use) can fix any number of sound problems...corroded contacts really balls up the sound but a quick clean and bobs yer uncle (usually anyway!)sonichima said:Nope.
Been too busy to look at it until today. I'll go down to maplin tomorrow and pick up some switch cleaner. Do you think that'll do it ?
Very good information. I will check mine too. I can't believe pioneer put those cheap piezo electric tweeters behind the big tweeter grills. It made me laugh when I opened up the unit.2steppa said:These are known for the solder pads stress-cracking where the function selector switch meets the PCB. I had to reflow / remake the solder joints on both of mine as they were crackling, popping and buzzing. Seems a distinct possibility in your case too.
BoomboxLover48 said:Very good information. I will check mine too. I can't believe pioneer put those cheap piezoelectric tweeters behind the big tweeter grills. It made me laugh when I opened up the unit.2steppa said:These are known for the solder pads stress-cracking where the function selector switch meets the PCB. I had to reflow / remake the solder joints on both of mine as they were crackling, popping and buzzing. Seems a distinct possibility in your case too.![]()
BoomboxLover48 said:[I can't believe pioneer put those cheap piezo electric tweeters behind the big tweeter grills. It made me laugh when I opened up the unit.![]()
And repeat after me: I, retrohead, am officially a proper jammy t...retrohead said:im onto my second now,bought yesterday for £10,and i concurr with 2 steppas mini revew,a lovely small box with the prestigious pioneer name![]()
