Pioneer SK-21 repair?
Kmulkey
I have a Pioneer SK-21 that I'd like to get repaired. I'm near Chicago in case anyone's close. Tapes will sometimes play for 10-15 seconds, then stop, or slow down. Sometimes the pinch roller doesn't engage but the capstan does turn. Also, the right hub either moves slow or doesn't move at all.
Thanks in advance.
Kmulkey said:
I have a Pioneer SK-21 that I'd like to get repaired. I'm near Chicago in case anyone's close. Tapes will sometimes play for 10-15 seconds, then stop, or slow down. Sometimes the pinch roller doesn't engage but the capstan does turn. Also, the right hub either moves slow or doesn't move at all. <br /><br />Thanks in advance.
<br /><br />I'm in Reddick maybe 60 miles south of Chicago and I can work on this for you. PM me ;-)
I have refurbished Kieths Pioneer and here is a quick explanation. I took back cover off and detached 2 antenna wires and hot and ground wires. Then I took all knobs off and took screws holding tuner/amp board in. Then took screws out holding in deck, speakers and a few other things. I removed everything carefully not to do any damage. I had to blow off all dust and dirt from everything. Took off grills and washed all plastic parts. Clean all switches and pots including record bar. Took deck apart to clean all dust and dirt and remove old grease. Clean heads and all tires. Demagnetize tape head. Clean good belts and replace bad ones. Put back together and hook up power to test deck. Adjust motor speed and azimuth if needed. Put new longer screw in amp board where post was slightly cracked. Put new screw in amp chip holding the heat sink to it. Dry all parts and put everything back together. Test all functions this is just a very simple explanation. It took approximately 8-9 hours and that's only because I had to take back apart to readjust motor speed on deck. Most deck motors face back of unit to easily adjust when back is off. But not pioneer and usually in better built boxes all wires are plugged for easy removal. But not pioneer, they are all soldered anyway her are some before and after pics :-)
oldskool69 said:
I have an SK-21 and have saved this for reference. :-D
The downfall is all wires are soldered in but it's not very big so it's pretty simple to pull it all out at once without desoldering ;-)
Shortstuff
To add to this I have a project box coming, got it for 45.00 needs a good cleaning inside & out + tape deck not working. I have taken soldering class and was certified now I need my own station!
