PHILIPS D 8534 FM problem
madera
Hi everybody. I have boombox PHILIPS D 8534. I need repair FM but i don't have electric scheme. :sad:
May be somebody have one? Please!!
Welcome aboard, madera. :-) What exactly seems to be the problem with the FM?
madera
Thanks for welcome. My FM doesn't work properly i mean i can't found any station. Sound bad, not clear,you listen noise not music or 2 stations at the same time. AM works good.
monchito
welcome to the site ,, depending on that tuner sounds like it needs some work , or if you are handy you might be able to try to find a replacement board off of a beater box and just swap ,,
Something has definitely gone bad somewhere along the FM tuner path. :-/ If you can find a copy of the service manual, you might be able to track down the problem.
