panasonic rs-462s question about plug port
decks&cassettes
the port on the side that says remote what is this plug port for is it for a walkman ? using the double ended headphone plug kind of like an audio in ?panasonic.JPG
Old tape recorder microphones had two plugs - one smaller than the other. There was also an on-off switch on the microphone that acted as a remote when recording.
decks&cassettes said:
so the port that says remote under the microphone ports is another microphone port ?
Yes. It is specifically for the two-plug remote control microphone. However, you can still use a regular, single-plug microphone in the larger port. You just won't be able to start/stop recording.
