Does anyone know what is the size of the pinch rollers for the RX-CT990? Thanks!
general682002 New Member Mar 1, 2023 #1 Does anyone know what is the size of the pinch rollers for the RX-CT990? Thanks!
general682002 New Member Mar 4, 2023 #3 hopey said: just measure the ones you have easy to get on line. Click to expand... Now, are the plastic hubs can be easily removed from the rubber wheels?
hopey Member (SA) Mar 5, 2023 #4 It's usually the axle that can be removed, it doesn't matter as long as it will fit in the housing as it's the pinion shaft that controls the speed.
