packing for 3 piece boxes ??
in the cases where the speakers have very solid locking attachments to the center section --
do you guys STILL suggest that each piece be wrapped separately ???
if the box is shipped --all assembled as ONE unit -
it makes for a smaller carton -
which is then more $$ efficient to DOUBLE BOX
opinions ???
thanks
ahardb0dy
I have never shipped any boxes but I would separate the speakers and pack them separately, maybe get a deep box and pack the main unit on the bottom and the 2 speakers on top, the speakers should take up the same space as the center section
MasterBlaster84
I would pack them seperate, most decent size 3 piece units can be around 30 inches long which to me would make it tougher to double box.
oldskool69
As the resident component box guy...seperate the pieces. If it is a unit with seperate reciever and deck, you can ship the center sections together as long as the end plates are firmly bolted/screwed on. Speakers always get wrapped individually.
Set the speakers evenly with the center sections, one at front and back. This protects the face and rear of the main section and the steel plates (if it has them) protects the sides. NEVER STACK SPEAKERS ON MAIN UNITS OR VICE VERSA ALWAYS SIDE BY SIDE. :no:
PC-55 I sent to HiFiTom before I boxed it below...
:-D
i would say if its a heavy component type box pack the sections seperatley ,if its just an average box thats not overly heavy then all assembled works great just double box and you should be fine.
SINISTER
Banned
a long time ago i got a 480 off ebay. i asked the seller to wrap it separate but..... he didnt. can you guess what happen :annoyed:
i forget --have not had a 480 for 3 weeks :dunce: :dunce: :dunce: :-)
does that model have a very positive //secure locking mechanisn ?
MasterBlaster84
Ummm, You received a minty perfect 480 without any damage at all. :sin: :-P
SINISTER
Banned
yeah right..............
blah blah
speakers packed off the body for sure. i have had two shipped to me complete, neither was a pretty outcome :nonono:
MasterBlaster84
NO. Only if your carrying it. :-)
Is the 480 one of the models where the locks are only engaged if the handle is up? I don't like that design. :no:
oldskool69
No it has a clip in the back. I was referring to shipping it that way. :-)
MasterBlaster84
I had a Sanyo C40 where the handle locked the speakers in place when it was up so if you placed the C40 on an uneven surface everything came apart even if you didn't want it to, I found that very annoying.
Sounds like the Fisher 460 and 480 use the same locking system.
Radio raheem
Requiem Æternam
The fidher 480 has a shite locking system it's fine if your carrying the box but if you listen to it on your lap because the locks for the speakers are at the bottom of the box, sometimes the speakers fall of grrrrr, i have cured mine though with the help a araldite i glued the speakers on perminently it was pissing me of the other way.
