Can anybody match the m90 paint colour and get the paint for me i have paypal waiting if sombody can get me a couple of tins of paint thanks
JVC Floyd said:i know the color is called tungsten gray metallic, did i spell that right.
LEDMeter said:Anyway, it's Holt's Dupli-Color, colour code DSH84, colour name is "Tunsten (Tungsten?) Pearl Metallic". I think the pearl factor might be a little shimmery, but the colour and metallic are good, so maybe you could get the colour made up at your local prestige auto bodyworks. I say prestige, as usually the top-end places have the best guys for colour matching. You could get them to make you up a non-pearl in the same colour in a can. Anyway the pearl might no be a problem for your job, as it's not too bad, just me being fussy.
Fatdog said:From S2G member LEDMeter:
monchito said:that may cost more rim because shipping of areosol cans if flammable will cost a bit more![]()
...it may be difficult to perfectly match the paint because you have to take into account the fading that occurs over the years...just my 2 cents...you're right satchfan. painting an M90 wouldn't go well.satchfan said:how do you paint the m90 with all the lettering? i can't see it going well
all the lettering would be destroyed. BMoney said:you're right satchfan. painting an M90 wouldn't go well.satchfan said:how do you paint the m90 with all the lettering? i can't see it going wellall the lettering would be destroyed.
how many M90 owners would even have the skill to lay down a proper paint job?
