If you cut back the bass frequency on the EQ, it can be a pretty good sounding box.One downfall to each is M70 has top mounted sliders that usually have issues and need rebuilding most of time where as TRC931 has a bad switch system for bands and function control that breaksBlack Dynamite said:How does it compare with the JVC MC70?
I did mean "RC-M70" its late here |-). Thanks for the advice!MONOLITHIC said:Assuming you mean the JVC RC-M70, the M70's bass is VERY weak in comparison to the 931, but it's better at everything else.
Yes but Lasonic in Shipping also breaks easilyBlack Dynamite said:I would like an M70, but finding one in my budget range is difficult, The Lasonic seems a bit more affordable.
Thats true. Ive searched high and low in my area and I cannot find ANY decent boomboxes so Ebay is about the only option.baddboybill said:Yes but Lasonic in Shipping also breaks easilyBlack Dynamite said:I would like an M70, but finding one in my budget range is difficult, The Lasonic seems a bit more affordable.Black boomers are not as sturdy
MONOLITHIC said:Best bass of any 1-piece box I've heard!If you cut back the bass frequency on the EQ, it can be a pretty good sounding box.
