JVC M70 tuner question
Matrixambience
I have a JVC M70 that is very difficult to recieve all my local FM stations in "stereo". The Stereo LED light won't light up when I fine tune the pointer at most of the familiar points on the analog dial scale. Is it a wire loose? Bad tuning cap? Every so often I can recieve an FM stereo broadcast, but have to really work with it. Both antennas are fully extended too. Also...how hard is it to replace the tuner scale light bulb...it is blown on mine. Thanks!
monchito
tuner um can be alot of things and without the right equipment trying to adjust can render it worse than how it sounds now ,, for what i have seen bad caps a bad transistor a lot of things can make it lose good reception,, on the stereo light either the 19khz pilot adjustment pot but at the same time the multiplexer ic ,,, for the dial lamp i belive its on the side of the dial meaning u have to remove the chasis to get to it and replace the bulb or check the switch also to make sure it does not have a broken connection somewhere ... :-)
Firstly, you did not indicate if it receives stations in mono, and if it does so with good reception. Use your tuning strength meter to help you if you don't know. If the answer is yes, the most likely cause is your 19khz pilot signal setting is off.
The fine tuning knob is for shortwave use and ineffective on FM.
The dial lamp is mounted beneath the right tweeter. You need to remove the chassis completely to fully expose the backside of the front cabinet. This lamp is soldered in place.
Matrixambience
Yes...it recieves stations in mono, the weak ones and strong ones, but since I have the switch to recieve in stereo is on, I would assume all my super strong local FM stations would come in stereo with LED on solid red, but it doesn't always. I meant by fine tune...by trying to use the large tuning knob and just move very slowly around the number scale of where I know I get stations in my area. My Panasonic RX-5085 has the best tuner by far in my collection, and use that one as a reference. Thanks for the advice, and I hope to get this one figured out.
Matrixambience
I am getting frustrated with my M70 and its inability to lock in my FM stations with stereo. I have the switch on stereo, and sometimes I get a particular station in stereo, then when I move the dial away from that station and go back to it, its flat sounding, and no stereo and stereo light won't come on. Anybody know here how easy it is to fix this? Is it for sure that pilot signal stength pot (19 khz). I love this boombox, and everything else works super on it. Anyone here have any ideas or want to fix it for me? The shipping back and forth makes me uneasy, but don't think no one locally will tackle this. That Radioactive Repair place near me, I have no faith in. They told me they couldn't fix my Panasonic RX-7700, and I sold it. Any help is greatly appreciated! Thanks! Jeff
Anybody know here how easy it is to fix this? Is it for sure that pilot signal stength pot (19 khz). I love this boombox, and everything else works super on it. Anyone here have any ideas or want to fix it for me? Jeff
Jeff. Nobody can tell you FOR SURE that it's one thing or another. But certain symptoms suggest certain failures and in your case, if your stereo capture is intermittent (sometimes it captures, sometimes it doesn't), then it's most likely the pilot signal adjustment, which adjusts the pilot signal frequency, not strength. You are adjusting for 19khz and normally done most accurately with a frequency counter. The simplified but less accurate method is to center R31 (on the M70) so that the stereo light illuminates at the 1/2 way point between the range of the pot where it lights. If you can never get the stereo led to light, then it could be the decoder itself has failed and the mpx decoder then will need replacement or diagnosis to determine if an adjacent component has failed.
Best thing is if you just attempt to adjust variable pot R31 yourself. That way you can save shipping costs back/forth. You have nothing to lose since it's not working right anyway. Just DO NOT ADJUST any of the other controls -- only pot R31. If you adjust the other trimpots, variable caps, transformer coils, etc.... you could throw the alignment off making it impossible to ever get it back, or require very expensive realignment service.
I am confident that I can fix this for you, if you like, but you'll not like the cost back/forth/repair. So if you can't fix it yourself, the brutal honest truth is that it's probably best for you $$ wise if you sell yours as-is, properly described, then use the proceeds to purchase another fully working one (from a trusted source, of course).
In the meantime, you should try the adjustment I prescribed above. You might be pleasantly surprised.
Matrixambience
Thanks Duper for the quick response! So...R31 pot is the one I can adjust, but I do not have a service manual for the M70, just owners manual. I do know some of those pots, diodes, and soldier joints are labled on some boards, is R31 labeled very well? Darnet...I just put it back together too! LOL! I may purchase a service manula for the M70 since I have two of them, and they kick ass! Thanks for the info, and I will try to adjust first and report my findings. Jeff
mellymelsr
...you can download the service manual from the Boomboxery "manual" section... :-D
Matrixambience
:-D :-D :-D :-D :-D :-D :-D :w00t: :w00t: :w00t: :w00t: :w00t: :w00t: :w00t: :thumbsup: :thumbsup: :thumbsup: :thumbsup: :thumbsup: :thumbsup: :thumbsup: The M70 is bangin hot!! I adjusted R31 pot and its pushin the speakers hard in true stereo FM signal with LED shining bright! Thanks for the super advice! The tuner light works now too...I sprayed some contact cleaner in the button and worked the switch and wiggled it around and now it works!! I am freakin flyin high!!
