JVC Deck Help
fresh produce
2,355
61
Sunny California
Hello everyone, I been using my 838 for awhile now and just recently the deck started playing the cassettes wonky and ruins the cassette, I'm assuming it might need new belts and maybe a pinch roller or could it be something else? Has this happen to anyone else? does anyone know where i can find some belts, the pinch roller and what are the sizes?
jerrymilton
22
59
Austin, TX
Belts can be found on Ebay.... not sure if you have the service manual yet... but here is a link: https://www.audioservicemanuals.com/j/jvc/jvc-rc/261475-jvc-rc-838-service-manual
Reactions: Tubejunkie
10,900
131
A service manual is also in the Boomboxery Library. Belts are listed as:
Belt FRM9.6
Belt SCY4.6
As for the pinch roller, I would say just give it a good cleaning. That might be all it needs.
5,763
276
In some cases a very light sanding of the pinch roller will also help. Basically remove a "nano layer" of the rubber surface. I used 1000 grit automotive grade 3M emery paper and lightly sanded the surface for a few turns of the wheel. Use light pressure with the emery paper making sure it is flat on the wheel.
~Royce
Ghettoboom767
4,307
56
Yes, could be pinch roller, one of my 838’s had a very hard pinch roller and it wasn’t being drawn through correctly, slipping and such so it would eat the tape. A good pinch roller is important anyhow as they get hard and brittle after 43 years!
