ION Boombox Deluxe Review
Transistorized
Went out and purchased the ION Boombox Deluxe today from Best Buy for US $69.99 plus tax. I was skeptical at first and when I saw how small it was, I was pretty sure the bass would sound like an ant stamping his foot on the tile floor of my kitchen. I was pleasantly surprised. I've had a few hours to play around with this little machine and I must say, this is actually the first reproduction boombox with cassette that seems to have gotten it right.
It has a powerful sound for the size and offers multiple ways to power it. Internal rechargeable battery, 6D batteries or AC mains. Despite showing tweeter grills, this boombox is only a 2 speaker setup with a condenser mic for open air recording. The speakers are 8 ohm drivers and have a decent \\throw// to them with a sensible magnet size. This gives them the ability to produce a warm low frequency. I would say that they are on par bass wise with a mid sized old school Panasonic. It truly gives a warm depth that surprised me and out performs the GPO in bass despite being twice as small. The bass radiates out the rear vents just like the good old days so placement is important as usual. The power to weight ratio is such to where it will literally move itself across a smooth floor or table on bass heavy songs. I would suggest adding rubber feet to keep it planted.
The radio picks up stations very well and has a true analog feel to the tuning adjustments. It has an AM/FM receiver with the option of Mono, Stereo and Stereo w/ Bass Boost. The radio performs as you would expect and has a stereo indicator light. Channel separation is very noticeable from Mono to Stereo on FM broadcasts.
The cassette deck is about as basic as you can get. It does not auto stop when Rewinding and F. Fwding but does auto-stop at the end of playback. It will shut itself off after playback is done however, you cannot use the cassette as a sleep function on radio. On the plus side, it records and plays cassettes in STEREO. Also, unlike the GPO, you can Rewind / F. Forward while on other functions (radio, Bluetooth, etc..). The only let down is the erase head which is a fixed magnet. This tends to introduce more background hiss and noise when recording but it seems to record as you would expect from an inexpensive boombox. You can record to cassette from open air (mono), aux (stereo), MP3 via Micro SD and USB (stereo), Bluetooth (stereo) and Radio (FM - stereo). Likewise, you can play a cassette and record it onto Micro SD / USB as an MP3. I found the tape head and motor adjustments on my model to be spot on. Treble was even and crisp on both channels with all of the cassettes I played through it.
Bluetooth was easy to pair and produces a more powerful sound than cassette. It allows you to be able to take advantage of your phones EQ settings for a more dialed in experience. I was able to coerce more volume, bass and treble out of my box using my phone as the playback source. The BT range is quite well. I walked from one end of my house to the other (one level approximately 55ft away) and the sound did not drop out or stutter at all. It is important to note that while in Bluetooth mode, the source determines whether you are stereo or mono. You can switch the selector on the radio to Mono but if your BT source is stereo it will continue to play in stereo. The good news is Bass Boost will still operate while streaming Bluetooth audio.
Micro SD / USB and MP3. I was fully expecting this boombox to record from all sources at a sample rate of 128 kbps. While playing Bluetooth I decided to record onto USB. I was pleasantly surprised to see that the sampling rate was 160 kbps! That is an improvement over the DJ-Tech, GPO and the Bumpboxx which are all 128 kbps. Its not the 192 kbps + I was hoping for....but 160 will definitely do and produces a recording that is desirable to listen to. MP3 Playback and Recording is fairly straight forward with the controls on the right side of the boombox.
The LEDs and Analog VUs scratch that itch regardless which way you prefer. The good news is that they aren't just a gimmick. They actually follow the audio output and are relative to the amplifiers output. You can also use them as a reference when recording.
Power is via AC, built in Rechargeable battery and/or 6D Batteries. There isn't a selector switch for the internal to external batteries so I assume the radio knows internally when batteries are inserted and will use those to power the box. The instructions were not too clear on this. I know you have to flip the AC switch on to charge while on mains. You can listen to the box while charging but the amplifier seems to pull current away from the charging circuit. When the bass hits the charge indicator practically goes out so not sure if that is disrupting charging or not.
If you want a compact lightweight boombox that's portable and won't break the bank, I recommend it. These look like one of those one off deals like the DJ-Tech that may be gone when they're gone.
I hope this was helpful for anyone considering purchasing one of these.
Wow, more bass than the GPO? That's impressive.
It says 2x7W RMS, which is decent for that size.
But why both rechargeable battery and a D-cell compartment? Seems odd, but I guess it extends the life outdoors.
Transistorized
But why does it have both rechargeable battery and a D-cell compartment? Why bother? Who today is going to use D-cells?
I thought the same thing Reli. The only time I can see using D batteries would be if you drained your internal one and were not around AC or didn't have time to charge it back up. It takes a good 6 hours to recharge once dead. I'm not sure if they're using NiMH or Lithium Battery in this. TBH if it truly lasts 10 hours like they say, I most likely will never need to use D's in this.
Weird they would pick 160 kbps for recording. I don't think I've ever seen that bitrate before.
That's a great looking boombox with just the right combo of features and its affordable,
nowadays I would rather buy something new that works rather than being Scotty from star trek always having to fix shlt just to have it do its job once then blow up lol
Reactions: David
I wonder if the same basic shell was already in use somewhere else, like the Middle East, allowing them to save money by re-purposing it. I mean it's pretty expensive to design and tool up a mold for a plastic boombox, plus all the switches and fake chrome.
It looks like an RX 5090 but the 5090 had sliders for the volume and balance control. That ion looks much better with the chrome buttons and switches because the panny version was pretty basic looking.
Bought two of them today, thanks for the tip Ryan! My friend's daughter is into boxes, she's going to freak on Christmas.
I think I might leave mine NIB, just to say I have one in my collection that is. haha
Reli, ION is a Numark brand, they've been in the audio game a long time and may have good sources for chroming/molding/etc.
Nickeccles
I'm tempted to get one of these & have been since first being aware of their existence!
I wonder if the UK has a reseller or stockist anywhere................
trippy1313
It's on my Secret Santa Christmas list for my wife's family. I'm really hoping I get it cause it's been hard getting her to let me buy anymore.
Can we get a size comparison pic? Maybe to an M70? I assume it's a little smaller.
Transistorized
Glad to help Eric :-)
So here is the scoop on this when you see its tiny size.
This first picture is the ION next to the M70. Obviously there's no comparison here other than to compare size. I had to get in and out quick with the camera as I could sense the tension starting to build :lol:
...but just to show how well it handles itself for its size, let's compare it against the GPO for which it outperforms in sound quality and volume
....and finally what its sound performance is equal to (bass wise and without Ambience on) to a vintage box. Now the RX-5050 blows it away in volume and edges the ION out in treble but they are both equal in bass. That's pretty amazing for its size
Is the ION going to blow your doors off? No.
Does it pack a punch for its size? Absolutely.
