hitachi 8290e volume problem..
javablue
hi,
i'm new here looking for some help,
i recently bought a hitachi 8920e from ebay,when i switched it on the volume was very very loud... even when volume sliders are set to minimum, position,i've cleaned all the sliders but no change...
any idea what would cause this?
thanks in advance,
william.
dubout
Welcome! Does balance have any effect? Not that I have any clue right now but if you give more information other board members might have an idea what causes the problem.
javablue
hi,
the volume sliders act as balance,when i move them up it gets even louder,the right channel seems louder at the minimum setting,both sets of leds are bouncing up & down with the sound,just far too loud at minimum setting.....
thanks for your reply
Sliders are shorting. A common problem with these sliders.
The need to be rebuilt by a qualifies technician or replaced.
It has to be at the highest resistance at minimum volume, and opens up to almost zero resistance at full volume. Normally there are at around 50K resistance in many boomboxes.
These sliders need to de soldered, opened up to see what is wrong with it.
Reactions: stynger007
javablue
will have to look into this a bit more just seen a hitachi trk-8300 on ebay that doesn't have sliders but has the exact same fault..
thanks for you reply..
