HELP SHARP GF9191 Left speaker?
mrjnr
Hello I am new to the world of BOOMBOXES and I have just got my very first BOX a SHARP GF 9191!! Im very happy with it but......
The left speaker plays very lower than the right and niether handle bass very well? what do you guys suggest.
Please HELP!!
You need to clean switches and pots with deoxit or contact cleaner spray. But before you do you must take back off. Spray small amount in small holes of switches and pots using straw then work each switch/pot 20-30 times. Wipe excess and let dry for a bit. Then test...good luck!!!
Northerner
It's amazing what a bit if switch cleaner will do...had a box that did nothing but give a slight popping noise...cleaned all the switches and it worked perfectly! I have a 9191 too and it's a nice loud box so I'm sure you'll get it running nice :thumbsup:
