Help for a sharp 8989, no sound from right speaker
weboguy
Hi everyone
I have a great Sharp GF 8989, but the sound is not coming from right speaker, just left
I opened it and cleaned all contacts and a quick check showed everything is connected as it should...
When I use the headphones socket the sound is on both channels, perfect stereo
When I turn the balance knnob full on the right, there is sound but very low, muffled and no bass
Can someone help?
Thanks
docs
Try and source the service manual, take a look at the block diagram, could help point you in the right direction as its possible there is an issue in the preamp phase.
weboguy
Thanks but I am no specialist and I don't understand anything in those manuals.....
Radio raheem
The speaker is probbably blown, this is a common issue with sharps, try it on headphones and see if both channels work
weboguy
Both speakers look perfect and similar, the wires and connections are good
On the headphones yes the sound comes in both channels and perfect stereo
weboguy said:
Hi everyone
Can someone help?
Thanks
Clean the record bar switch and see how it sounds. Switch the speakers and see if there is a problem with the speaker.
weboguy
what is it the record bar switch ?
how do I switch the speakers? I have nothing to desolder / resolder them sorry I have nothing to do this
I precise that both with radio and tape playing it's the same, no sound (or barely) from right speaker
weboguy
docs said:
external speakers an option?
no lol....
I have found the service manual, and block diagram...
Well this is chinese to me!!!!!!!!!!!!!!!!!
There is a thing called "stereo switch", could it be this?
But of course I don't know where it is and how it looks
Sorry I surely sound stupid but again I am completely zero in electronics
It's a shame because the boombox is great cosmetically and sounds great, just not sound on the right
For a guy like you all here, surely is something you would resolve in a minute....
docs
put a blank tape in, put it in radio mode, press record and stop a couple of times and repeat for a while, does it affect the low channel at all?
weboguy
ok wait I do this and I tell you after
thanks for helping me that's nice from you guys!!!
ok done it 20 times...it lowers the sound then goes normal volume again, but, still, no sound on the right......................... :bang:
listen : when I play my recording, there is no sound at all!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! or just very very low on left channel..................
stevenrob
Do you have clean all the pots and the switch record/play? The same problem with tape or radio ? Do you have try to plug the other speaker ?
weboguy
je suis français aussi
oui avec la radio et la cassette, même problème!!
par ailleurs le lecteur de k7 fonctionne parfaitement dans toutes ces fonctions
je n'ai pas branché d'autres haut parleurs car je n'y connais rien, je ne saurais pas désouder et resouder les trucs....
quand on tourne la balance a droite complètement, il y a du son mais tout bas, étouffé et grésillant
j'ai mis du nettoyant contact un peu partout, bien laissé sécher et tout remonté et c'est pareil...
c'est dommage le poste est superbe et je l'aimebeaucoup^je suis vraiment embété...
quant au service manual disons que c'est du charabia pour moi lol je n'y pige que dalle...!!!
weboguy
Oh everyone : I forgot to say, just maybe I should have told first thing lol!!! :
When I received the box, the magnet from the right speaker, the non sounding one, was not more attached to the speaker and was stuck inside the box...
So I glued it back on it..
Can it be the reason why there is no sound?
Sorry I forgotto say that....
L'aimant qui est attaché au haut parleur droit n'était plus dessus et se baladait dans le boombox quand je l'ai reçu...Je l'ai donc remis en place avec de la glu
Est ce la cause du problème?
If this is, I think I can find an old 8989 just to replace the speaker, I can do this
Si oui, je pense pouvoir trouver un vieux 8989 pas cher, juste pour remplacer ce haut parleur, je pense savoir le faire, juste 4 vis et 4 soudures
Thanks!
Merci!!
weboguy
hi again
well I tried to plug another speaker instead of the right and..it works!!!!!!!!!!!!!!!
so I just have to change the speaker and that's fine
not easy to find one, 16cm, 3.2 ohms, 4/8 watts or maybe find an old gf8989 just to grab the speaker
if anyone has one pm me please
thanks!!!
Thanks!
Merci!!
Kind of valuable information there :lol: Glad you were able to figure it out. Post up in the wanted section that your looking for a speaker, someone surely has one
Northerner said:
:-D
