Helix HX-4636 Battery Cover Wanted
goill773
Hopefully I can get lucky and someone has a spare battery cover for the Helix HX-4636? I'm assuming there are other AKAs from other manufacturers of this model that might work as well. I got my fingers crossed...thanks everyone!
:bow:
Check the pics below, the outside looks identical to the Wheely.
The inside looks a bit differerent - not sure if it's enough to matter, I don't own either box.
I never took any pics of the Wheely cover when I drew it a couple years ago for someone, but you can see the inside here.
Anyway if it turns out it's the same, you can buy it here or with the logo here
Wheely:
4636:
goill773
That looks like a solid replacement. It’s just a little pricey… almost the same price I scored the box for. Good to know there is a printed option though.
Thank you for the links, I’ll definitely save them in case I pull the trigger.
